Headlight lens removal
Old 09-29-2017, 04:44 PM
Blacktt3z's Avatar
Default Headlight lens removal
Is there any way to remove this lens so I can clean it and re-seal it?
Old 09-29-2017, 04:54 PM
JUKE179r's Avatar
I've read people heat it up in a oven to soften the glue around the lens and peel it off. Kind of scary to me...
OffroadFrance (10-01-2017)
Old 09-30-2017, 01:34 PM
Friday Night Disco's Avatar
I have done this on many Subaru headlights but, not a Land Rover...
Short story is, you can do this but, know before hand where all the tabs and screws are and have the tools ready as the headlight cools off fast.
I would say buy a broken one and test out the process first.
Here is a video
Old 09-30-2017, 05:45 PM
Hi, I've never opened a facelift headlamp as yet, mine has the same type, but it may be possible somehow but I reckon it's high risk both 'cooking' it and also resealing it afterwards.
Old 09-30-2017, 10:01 PM
Sixpack577's Avatar
It's not a big deal.
200 F degrees for 5 minutes, check, then 5 more.
Most ovens don't set lower than 350 F, so a temperature gun is needed.
All you are doing is warming and softening plastic tabs.
That way, when you flex the tab up to release it, it doesn't snap off. As said above, be ready to work fast.
Once the clear lens is popped off, you can let it cool, clean it, run a fine bead of clear silicone, and snap it back on. I have to do the passenger side on my 04, as soon as I fix 10 other things.
Old 10-01-2017, 09:56 AM
Blacktt3z's Avatar
thanks! can you do it in your home oven or will the fumes ruin it?
Old 10-01-2017, 10:30 AM
Sixpack577's Avatar
Yes, and there aren't any fumes.
You're not heating it up enough to melt or burn it.
Just warming it enough so the plastic is not brittle, and the clips don't snap, especially with it's age.
I would put it on a foil lined pan, and watch it carefully, as all ovens are different. Some heat up faster than others.
honda50r
06-11-2011 03:36 PM
jasonrusso
05-28-2011 10:23 AM
elitepro
Audio/Visual Electronics
03-13-2009 06:48 AM
bugg
10-14-2006 09:44 PM
Quick Reply: Headlight lens removal
