headlight washer
RE: headlight washer
On a DI you can see the bolts if you lay down underneath the vehicle and look up, you will see the two hoses and it will be fairly obvious..
Mine dont work, I think whatever solenoid lets the fluid get pumped out when the lights are on must be bad.. My windshield ones work, but the Headlight ones dont..
I had something odd just start happening with my 98 DI during our ICE Storm in Arkansas. When I turn on my headlights my headlight washer just started working but also my windscreen wipers stay on while the lights are on. The wiper switch works but the windscreen sprayer stopped working. I think it is the contol arms have shorted possibly I am still checking. Dont you just hate the two bolts under the washer fluid container in the wheel well that will not come loose. Anyone have this problem?
ORIGINAL: llPANCHOll
ORIGINAL: grussell
My headlight washer dont work. I jumped the pump and it works and the fuse is good. Is there a relay somewhere?
My rear washer doesnt work either, but I checked everything and it appears the one way valve is no way. I cant blow through it at all.
They are all controlled by the MFU on the back of the fuse box. There is a self test for it on here, but don't remeber where. I will try to find it. You have to have your lights on for the headlight washer to work, and it works every third pull of the front washers.
found it:
Diagnostic Procedure
1. Close all doors and the tailgate.
NOTE: If the oil pressure switch goes open circuit
(engine is started) during the following procedure,
the MFU will exit the diagnostic mode immediately.
2. Press and hold the heated rear screen switch
and switch on the ignition.
3. Release the heated rear screen switch within 2
seconds and the MFU will beep to indicate that it’s in
diagnostic mode 1.
4. Press the heated rear screen switch; the MFU
will beep twice. In turn, operate each of the following
switches, heated front screen, rear fog guard lamps,
side lights, headlights, front wiper and rear wiper.
The MFU will beep twice each time a switch is oper-ated.
5. Pressing the heated rear screen again will cause
the MFU to enter diagnostic mode 2.
6. The MFU will provide outputs to the following in
order given below:
Heated rear screen relay energised for 2 seconds
Heated front screen energised for 2 seconds
Courtesy lights energised for 2 seconds
Dim dip relay energised for 2 seconds
Rear fog guard lamp energised for 2 seconds
Headlamp power wash energised for half a second
Front wiper energised for half a second
Rear wipe/wash energised for half a second
7. The MFU will then exit the diagnostic mode.
diagnostic mode 1.
order given below:
