Headliner Replacement - Average Cost?
Old Oct 13, 2008 | 03:08 PM
jmt's Avatar
jmt
Default Headliner Replacement - Average Cost?
Anyone know about what it should cost to replace the headliner in an 03 DII without sunroofs?
I want to make sure I'm getting accurate quotes when I start calling some shops.
Old Oct 13, 2008 | 04:45 PM
Goose_Cat's Avatar
Default RE: Headliner Replacement - Average Cost?
Did mine for 170, but I had to do the removal and install
Old Oct 13, 2008 | 05:55 PM
heromanLSU's Avatar
I had a guy do mine for $280 with 2 sunroofs.
Old Oct 14, 2008 | 01:27 AM
CandiMan's Avatar
ORIGINAL: jmt
Price quotes vary per city/state.
[ul][*]buying 3yds of material at your local supplier might cost you $25[*]buying 3yds of material on-line might cost you $50-70[*]you doing the remove and install and bringing your board to a shop might cost you $150-170[*]droping your truck at garage and letting them do everything might cost you $280-300[/ul]
All the above price is a guess on my part.
Old Oct 14, 2008 | 09:41 PM
redROVER00's Avatar
3rd Gear
i'm in baton rouge...where did you get yours done & do you recommend them? i was thinking of tackling it myself, until i saw what you paid.
thanks.
Old Oct 14, 2008 | 10:54 PM
Switzer's Avatar
Did mine for $50.00. I stripped out the old saggy liner and sprayed rubberized 3M coating in its place. If I could do it again I would spray closer to the headliner board and in thinner coats. Overall I like it and it seems to work well. It is also slightly quieter since the rubber coat absorbs more sound.
Cheers,
Pete
[IMG]local://upfiles/10333/8EF750B697BB4636AD70B79B4494450D.jpg[/IMG]
[IMG]local://upfiles/10333/1E43DD7453E6422DAFFD927FDA00B080.jpg[/IMG]
[IMG]local://upfiles/10333/855E59BF1C0C4723AA090C16045D82EE.jpg[/IMG]
Old Oct 16, 2008 | 09:34 PM
fri3daz3's Avatar
I just got my headliner done yesterday for $200 with 2 sunroofs with a lifetime warranty (as long as you own the car). By the way, I'm from San Diego. It took them a day to finish it, but he said they could get it done by noon if you drop it off around 8am. The guy was really nice and courteus. I would definitely do business with them again.
Call them up if you live in or around San Diego, CA.
Ming's Upholstery
858.486.3268
I dont know the exact address, but they're located in Poway (North SD.)
Good Luck!
FlyingZebra34
Mar 7, 2014 01:05 PM
TATZOO
Sep 27, 2012 08:44 PM
nsfour
Apr 3, 2011 06:53 PM
84crawling
Oct 4, 2008 11:30 AM
mht2007
LR2
Jan 19, 2008 07:21 PM
