Headliner Replacement - Where To Stop Prep
Old Jan 10, 2014 | 10:54 PM
04duxlr's Avatar
Default Headliner Replacement - Where To Stop Prep
So I took the plunge and started my headliner repair tonight. I pulled it out in about an hour then started in on the foam with the wire brush. It came right off, but beneath the foam is a green felt with thin black felt/foam behind it which is attached to the fiberglass headliner shell. Most of the green felt was glued down pretty well but some areas had started to lift. I pulled those areas up and a bunch more peeled off also but now I'm not sure if I need to get it all off or if some can stay. Has anybody run into this?
Old Jan 10, 2014 | 11:17 PM
Daedrix's Avatar
Banned
Can you take a pic of what you are talking about. I don't remember running into anything green when i did mine.
Old Jan 11, 2014 | 12:53 AM
dusty1's Avatar
Green felt? New one on me. Sound like you got lucky. have you tried water or chems?
Old Jan 13, 2014 | 03:51 PM
04duxlr's Avatar
Here's a few pictures of what I found. The fabric fell right off, then the foam brushed off without much effort at all. Below that was what seemed to be a green felt, but if I peeled that off there was a non-woven black polyester fiber material. It was folded into the headliner in some areas so it was probably placed in the mold with the fiberglass when the shell was formed. I wanted to get the thing finished so I pulled off whatever I could and figured if it couldn't be pulled off it wasn't coming off. Trying to scrub off the black stuff started to break down the fiberglass. I sprayed it with the adhesive and put on the headliner material and called it good. If it comes apart in a few years, I'll just do it over. It actually looks great, although I haven't taken any pictures of it in the truck yet.
Attached Thumbnails Headliner Replacement - Where To Stop Prep-pic-2.jpg   Headliner Replacement - Where To Stop Prep-pic-6.jpg   Headliner Replacement - Where To Stop Prep-pic-8.jpg
Old Jan 13, 2014 | 05:16 PM
04duxlr's Avatar
Here's a picture of the headliner in the truck. Makes a big difference not having it draped over the occupants heads.
Attached Thumbnails Headliner Replacement - Where To Stop Prep-image-729531541.jpg
Old Jan 13, 2014 | 05:51 PM
dusty1's Avatar
Well, that definitely looks better. Nice work
Old Jan 13, 2014 | 06:13 PM
mattmo78's Avatar
I'm planning on doing this in the future. But I'm curious if your headliner had been redone in the past, and that was what you were seeing? Just a thought. Was it hard to remove and replace the headliner?
Old Jan 13, 2014 | 06:21 PM
04duxlr's Avatar
Not sure if it had been redone. If it was, they used the same crappy materials and glue as the factory so I doubt it.
The headliner came out in about an hour. It was pretty easy and the results are worth it. I got the material and 2 cans of spray adhesive from WLS Headliners for about $110 delivered.
Old Jan 14, 2014 | 07:26 AM
drowssap's Avatar
look great
Old Jan 14, 2014 | 03:05 PM
Daedrix's Avatar
Banned
Looks great. If you plan on removing it again you can do what i did to add more light.
