Headliner: tear down for new fabric
Old Nov 2, 2020 | 10:07 AM
ReconDoc83's Avatar
Originally Posted by TimInNova
I finally fixed my two leaky sunroofs. I installed new 3D printed hose connectors, used 3M Marine sealant between the frames and the roofs as well as the glass bolts, and installed new rubber gaskets. While I had it apart I decided to add sound-heat insulation to the roof and redo the headliner with some material I picked up on vacation in Hawaii last year. I first glued down a thin foam, then glued the palm leave fabric on top of that. The material is stretchy, like spandex. I think it's known as "Performance Piqué" fabric. I used 3M headliner glue. I also left out the nets, as they are useless.
outstanding!
Old Nov 2, 2020 | 01:12 PM
TimInNova's Avatar
Originally Posted by ReconDoc83
going with a very classic looking Burberry pattern. If all goes well, I’ll post pics when finished.
gonna do the door cards too.
That Burberry is going to look amazing with the black interior. Please post pictures when your done.
Old Nov 3, 2020 | 04:44 PM
redrover75's Avatar
Stripeyze, or something spelled similar makes very short work of removing the adhesive, foam, etc.
Old Nov 4, 2020 | 08:05 AM
baileyrockhound's Avatar
I removed the foam etc. on two headliners just using heavy leather gloves and some mild elbow grease. just the friction was enough to strip it off.
Old Nov 4, 2020 | 11:20 AM
Harvlr's Avatar
On the P38, I removed all the old foam with a wire brush. Then replaced the headliner with new foam backed headliner material. Not a difficult job, but a bit fiddly.
Old Nov 4, 2020 | 08:27 PM
Richard Gallant's Avatar
Do you have the fabric size you used
Old Nov 5, 2020 | 08:54 AM
shanechevelle's Avatar
I like the fabric as it is different.
Do you think you will get tired of it?
I was contemplating using a british flag and doing the same thing or a large "Land Rover" symbol
Old Nov 5, 2020 | 04:04 PM
TimInNova's Avatar
The fabric was only 54" wide, so I had a seamstress cut it and sew it to give me a piece 64" wide x 108" long.
Old Nov 5, 2020 | 04:05 PM
TimInNova's Avatar
Only time will tell
Old Nov 5, 2020 | 06:52 PM
@TimInNova thanks
