Heads off see pics...
So I got the heads off and the gaskets look okay. heavy coolant in the rear pistons. Everything came off almost too easy, the manifold and head bolts were not on that tight. I take the heads to the machine shop tomorrow to have them check them. I wonder if my leak was due to the head bolts not being tight enough...
Port and polishing is a performance enhancement in improving the performance of the cylinder heads, very popular as an aftermarket modification in high performance cars. It is not required to do if you are happy with the way your car's engine performs in terms of it's power delivery.
Anything w-30 is to thin for these engines, thats why you have so much sludge and varnish.
The oil cannot withstand the heat and is breaking down.
How often do you change it?
