Heads probably a ticking time bomb
Old Dec 11, 2013 | 03:04 PM
  #31
slabrat's Avatar
Originally Posted by drowssap
The coils only need to be removed so you can get to the middle bolt on the upper plenum, the upper plenum need to be removed to get to the inner VC bolts.
Really not a big deal I had to replace my coils this weekend so I replaced my wires and plugs while I was there total time 3.5 hours including the front 02's outside lovely NE weather.
there is a total of 8 bolts for the upper plenum, 2 for the coil bracket, everything else is a plug or hose clamp.
I dont remember taking the coils out when removing the Upper intake. I just loosened them. But good time to change plug wires
S Buzz says he can tighten his without removing the upper intake. I have never figured that out. Must have some kind of weird looking tool. Looks like it must be attacked from the front ??
Anyway Like Drow said best time to replace the Plug wires if needed while all this is apart . It is recommended to replace the upper intake gasket after removing it.
Cheers
Old Dec 11, 2013 | 11:25 PM
  #32
TRIARII's Avatar
Plugs wires and unknown coils where already replaced by previous owner roughly around 100K. Currently the truck has 134K so I really dont believe I should be worrying about them now. Thanks for the tips. I already tightned 4 bolts I could reach without tearing everything apart and topped off the oil. Have my eye on the oil dipstick and so far so good...
ellebarto
Defender
Jun 11, 2013 05:53 PM
jrmdir
Apr 8, 2013 11:18 AM
grandkodiak
Aug 31, 2012 08:05 AM
Fivespddisco
Sights N Sounds
May 21, 2011 11:11 AM
audiS4S6
Apr 22, 2010 08:48 PM
