Heads up - Britpart Elbow Pipe Failure
Old 07-13-2018, 08:19 AM
CollieRover's Avatar
Default Heads up - Britpart Elbow Pipe Failure
Hey Guys. Just a public service announcement. I put in a Britpart Coolant Elbow Pipe when I did my head gaskets a couple of months ago, and it has failed.
Also, I got a Genuine from the Dealership for less than a genuine advertised online.
Should have kept my original, but it had a nasty ding where it married to the hose, and I did not want leaks.
It has developed a crack at the weld where the bracket to the alternator bracket is.
I am growing increasingly disillusioned with Britpart.
The following 2 users liked this post by CollieRover:
Sixpack577 (07-13-2018), The_OGCJR (07-25-2018)
Old 07-13-2018, 11:48 AM
Best4x4's Avatar
Received 2,272 Likes on 1,676 Posts
Only thing I use by britpart is their thermostat (which I’m sure they don’t even make in the first place). I doubt they made the coolant pipe either. URO is the brand I avoid like the plague though.
Old 07-14-2018, 07:14 AM
I used URO breather hoses, which are so simple and under so little stress I hope they end up fine. The URO valley pan gasket clamps I got did not fit, not even close.
I'll be avoiding them in the future as well.
Old 07-14-2018, 09:45 AM
Jeff Blake's Avatar
Back in my early days I ordered a URO parts coolant reservoir... it looked like it came from Toys"R"Us
Britpart is a life saver for a lot of parts, I probably buy 80% britpart. Things like seals, hoses, and o-rings I stick to genuine... as there is a very noticeable difference, especially with seals.
Old 07-14-2018, 10:08 AM
dtmbinb's Avatar
Before I replaced my engine, I had a few URO hoses. They began to leak at the house clamps. Tighten one, drip at another. Junk!
Old 07-14-2018, 12:53 PM
Best4x4's Avatar
Yeah I had a URO reservoir on one of my D2’s when I bought it. I went to fill it & I ripped the entire neck off with the cap.... I cringe now whenever I see URO on a LR.
Old 07-18-2018, 10:36 AM
Just picked up my Genuine Elbow Pipe. My goodness, the Britpart is flimsy in comparison.
Old 07-18-2018, 05:20 PM
Jeff Blake's Avatar
URO does make one worthwhile part! The plastic fuel door latch
Old 07-18-2018, 08:18 PM
Even the Britpart O Ring was **** poor. The genuine is much thicker.
Old 07-25-2018, 08:09 AM
You can see the crack that the Britpart Pipe developed. Less than 1,500 miles, disappointing.
OverRover (07-25-2018), The_OGCJR (07-25-2018)
Quick Reply: Heads up - Britpart Elbow Pipe Failure
