Heat causing battery drain!?
Old Jan 16, 2019 | 10:16 AM
Blanco.se7's Avatar
Default Heat causing battery drain!?
So yeah, I’m posting about this a little late but it’s been about a month without heat and I can’t take it anymore! Basically, I parked my truck to wash it, got it all washed up, and then it wouldn’t start, it had power to the cluster, but the battery drained in a matter of 35-45min, odd, so I thought it could be the battery so I charged it up, and it started, so I moved the truck parked it, and came out 30 min later to make a grocery run, and boom, dead again, finally after much much pulling and starting and pulling and starting, I found out it was something to do with the heat, so I pulled the fuse to the whole heat/ac system (for just the front of the cab, so the rear seat heat/ac works) And now the battery holds a charge, ive gone too long without heat and it’s been mid to low 30’s at best lately, anyone got some advice as to where I should start?
Old Jan 16, 2019 | 11:42 AM
escott16's Avatar
Which fuse ?
does the fan run with the car off
Old Jan 16, 2019 | 04:15 PM
Blanco.se7's Avatar
Originally Posted by escott16
Which fuse ?
Old Jan 16, 2019 | 04:37 PM
escott16's Avatar
Isn’t that the abs fuse?
Old Jan 16, 2019 | 04:41 PM
escott16's Avatar
Old Jan 16, 2019 | 05:04 PM
Blanco.se7's Avatar
not according to my owners manual? Even if it is, how come me taking it out messed with my heater/ac
Old Jan 16, 2019 | 05:08 PM
escott16's Avatar
Look at the pic you posted compare the owners manual pages with the amps on the fuses , it starts from the bottom
Old Jan 16, 2019 | 05:10 PM
escott16's Avatar
It’s descending order
Old Jan 16, 2019 | 05:24 PM
The Deputy's Avatar
Yes, you pulled fuse #11...ABS valve. On lefthand page, showing fuse box...#1 starts at the bottom and #16 is at the top.
​​​​​​​ Brian.
Old Jan 16, 2019 | 05:30 PM
Blanco.se7's Avatar
Brian.
so this means something with ABS was causing my drain?
