Heat distribution box
Old Jan 4, 2013 | 08:18 PM
Bob Jones's Avatar
Default Heat distribution box
Has anyone got experience repairing the distribution box? The vent at passenger door has no air at all. And the other passenger vent is far cooler then driver side at same setting. Looks like a PITA to get to it. Is the airbag going to cause a problem? I cleaned the fan about a month ago and have good air flow on both driver side vents. I don't want my wife to freeze every time we go for a drive.
Old Jan 4, 2013 | 08:52 PM
Bkreutz's Avatar
It is indeed a PITA to work on the box, sounds like you've got blend doors sticking or not working at all. The airbag is really a non issue, it just bolts into place. The real pain is removing the dash to access the heater box.
Old Jan 5, 2013 | 12:13 AM
909wheeler's Avatar
Probably a cheaper fix...
Old Jan 5, 2013 | 10:33 AM
Bob Jones's Avatar
So are the doors that direct air flow serviceable?
Old Jan 5, 2013 | 11:21 AM
Bkreutz's Avatar
Sort of, The servos that operate the blend doors are external, the doors are internal, I've seen some successful repairs done, but most of the time the doors and links (which are plastic) have deformed or broken due to age and the only repair was to replace the distribution box. You might consider looking for a good used one. Do you have a RAVE manual, if not you can download one here land rover service factory manual RAVE download land rover resource, service manual, workshop factory manual, download, rave, vehicles including discovery, series, defender, range rover, freelander, LR3, Handbooks, Catalog, Catalogue, Land Rover Inte I would suggest downloading it and reading about the HVAC system as it's quite involved to do repairs on it.
wrongway1
Dec 8, 2013 10:24 AM
droptine77
Nov 3, 2013 03:47 PM
fern540
Aug 17, 2013 09:50 PM
Ray Sham
Jun 4, 2013 10:02 PM
marcolanza
Feb 20, 2006 02:17 PM
