heat at feet
Old Feb 14, 2007 | 06:45 PM
swellseeker's Avatar
Default heat at feet
Is it normal for heat to come out near your feet while driving when the climate control is off? My Isuzu Trooper used to do this, but not as much heat as my disco II. Gets very annoying in warm weather.
Thanks
Sean
Old Feb 14, 2007 | 09:43 PM
Default RE: heat at feet
It is not normal, sounds like your control head may be on it's way out.
What happens when you turn the unit off, does it still blow hot at your feet?
There is a self testing program that will test and give you a fault code. If you are interested let me know and I'll try and find the test for you.
Mike
Old Feb 15, 2007 | 02:15 PM
It does not blow , but rather "leaks" hot air after driving for a short time. If the climate control is off, heat seems to slowly come out near my feet like its being forced in by outside wind through the system.
honda50r
Mar 8, 2012 06:38 AM
honda50r
Nov 5, 2011 01:13 PM
Rover Chris
Oct 2, 2010 09:39 AM
pvenuti
Apr 17, 2010 05:20 PM
84 GRANDSPORT
Feb 15, 2007 11:24 AM
