Heated seats...GREAT SUCESS!!!
Old Mar 20, 2013 | 06:33 PM
symaxwell's Avatar
Default Heated seats...GREAT SUCESS!!!
So I have been reading that my 2004 HSE might have heated seats and all the wiring just not the switches and that a simple switch install would give me heated seats. WELL BOY WERE YOU RIGHT!!!
Saw on AB that they sold a kit for almost $200 to do this very thing and decided had to be cheaper to just get used parts. Jumped on ebay and found a complete unit for $40. So worth it. Did the install today and worked like a charm.
Had a couple snags. First the trim piece that comes with my HSE is a solid piece from shifters to windows switches. I guess because of this it doesn't screw in but instead fits via pressure. So....the bracket that comes with most discos screws into metal tabs on the center console. I need to purchase these metal brackets and screws and the cover to make it look nice. See photos below. I'm thinking I can get the screws and metal fittings at home depot. Any tips or advice for this?
Finished product so far
Missing metal bracket that slips on the plastic tab to allow screws.
Old wood center piece. Should i sell it?
See metal tab at top of this trim for press fitting in. NO screws.
Well that's my 2 cents. I'll post a picture when i get the trim installed.
Old Mar 20, 2013 | 06:43 PM
NickAdams's Avatar
"Old wood center piece. Should I sell it?" I know, were it me, I would use that needs-to-be-modified-wood-trim-piece as the perfect excuse to buy a new tool, like a Dremel with every accessory made. That way, you could custom fit and re-use the wood trim.
Old Mar 20, 2013 | 06:47 PM
ZGPhoto's Avatar
Everyone should own a dremel, they're so useful.
Old Mar 20, 2013 | 07:10 PM
04duxlr's Avatar
So true. I bought an air powered rotary tool for $20 that takes all the dremel accessories. It's great, plus it makes that same awesome noise that dental tools do. Very soothing.
Old Mar 20, 2013 | 07:37 PM
iambhooper's Avatar
I bought the $100 kit 4 years ago and have used it thrice! But this would be a good use for it.
Before you cut, put masking tape the face and back of the wood trim, make a template from some heavy paper and tape that on top of the tape, then score the template with a heavy blade. Do this before using the dremel, and cut a smaller opening than you need.
Old Mar 20, 2013 | 09:48 PM
ZGPhoto's Avatar
Does it let you adjust RPMs like the Dremel does? That was a huge plus for me when I was making the decision. One thing I do crave for is the air powered micro sawzall thing, almost no sparks but cuts all the same. Great for tight corners and interior stuff.
Old Mar 20, 2013 | 09:50 PM
symaxwell's Avatar
I dunno. I'm thinking of not cutting it. I like the look of the rubber mat and the black plastic cover. The wood is nice but not very utilitarian. Once i get the black cover for the buttons i will probably sell the wood piece. What do you think its worth?
Old Mar 20, 2013 | 10:23 PM
04duxlr's Avatar
Yup, from a barely annoying whine to a full on scream. They had a pile of them at HD for $40, and I waited until they dropped the price to $20 and grabbed one. Very Asian but it works pretty well just the same. I have one of those air saws as well, but it isn't as cool as I want it to be. The blades heat up and bend before I know what happened. If I could find a good source for better blades I might like it more. One of my favorite air tools is an impact screw driver. With an adapter it makes a great 1/4" impact gun as well. Pretty unnecessary but neat just the same.
Old Mar 21, 2013 | 12:21 PM
symaxwell's Avatar
Somehow this became the dremel forum. I do have a Dremel but prefer the non wood look. So maybe someone else can have it and try for themselves.
Old Mar 21, 2013 | 12:36 PM
04duxlr's Avatar
Nope, just the Dremel thread. Hope you're able to find hardware to finish up the project. I'm surprised that an HSE didn't come with the switches in place already. I didn't think there were any options left off of those.
