heated windshield plug/wire
Just had windshield replaced on my 2004.The driver's side works, but passenger side does not work. Both plugs get power, but I notice the wire colors don't match up on the passenger side. Purple is going to black. Is that the problem? Can somebody check thier truck for me?
Ooh, I can’t recall how it was on my ‘00, but I’m going to put a heated windshield in my ‘04, so I’d like to know this as well.
But to be productive, maybe put a meter to the posts on the side that isn’t working and do a continuity test? If you get tone on the side that works, but not on the side that doesn’t, I suspect you got a bad windshield.
Ooh, I can’t recall how it was on my ‘00, but I’m going to put a heated windshield in my ‘04, so I’d like to know this as well. But to be productive, maybe put a meter to the posts on the side that isn’t working and do a continuity test? If you get tone on the side that works, but not on the side that doesn’t, I suspect you got a bad windshield.
When you say "fails the resistance test" are you referring to the windshield not having any resistance or the truck side having no resistance? Your windshield should definitely have resistance because the heated windshield is a giant resistor and the truck side should be an open circuit when the heater is off (and 12V when on). The colors on the plug shouldn't matter, the heating element in the windshield doesn't care about the polarity of the electricity.
I'm pretty sure that would be a terrible design. I have one or two bad elements in my windscreen, and the rest still work. Like the rear window defroster...front is likely a parallel set of resistor elements. Probably the tape connector fried/failed....
¯\_(ツ)_/¯ I very well might be wrong but I've read this elsewhere long ago when I first got our disco and was trying to figure out why the windscreen wasn't heating. It ended up being that it needed to be "activated" by the Nanocom.
