Heated windshield problem
Old Dec 11, 2008 | 09:24 AM
hpipe's Avatar
4wd High
Default Heated windshield problem
Hi, I did a little searching but did not find anyone with this specific problem.
I tried my heated windshield the other day and only about 10% of it worked...all of that 10% on the drivers side. There was a few inches just to the left of the steering wheel and another inch or two to the right of the steering wheel.
I've seen posts about checking fuses, but as far as that driver side, if part of it works, what could be keeping the other parts from not working?
I didn't see in the posts where to look other than the corners under the hood.
Thanks!
Old Dec 11, 2008 | 10:11 AM
Darover's Avatar
Default RE: Heated windshield problem
check under the hood to make sure that the relay is fully pressed into position. Then I<d suggest you clean the plug-in on each side.
Old Dec 11, 2008 | 07:35 PM
hpipe's Avatar
4wd High
Thanks...I checked both of those areas and they both looked pretty clean and the fuses were good and pushed in.
Any other ideas on why only parts of the heated windsheild work (primarily Driver side)?
Thanks!
Old Dec 12, 2008 | 09:06 AM
Darover's Avatar
Well, what I'd do now, is use a multi meter to make sure that current is making its way to the windshield.
BTamas
Jan 8, 2013 01:39 PM
PKG Vitesse
Nov 27, 2011 08:07 PM
BostonBB
Oct 9, 2007 05:32 AM
wimp
Oct 28, 2006 05:17 PM
