hello guys new to this forum
Hello dear LR lovers . I have a disco2 td5 manual . I have a problem with my gearbox i think.rebuilted my gear box 4 times and it runs couple of month.and it makes noice when i push the release clutch and try to change shafts it makes noise. later my engine crankshaft rear copper ring has been busted so what did i do wrong for my gearbox . Help me guys
You're going to have to explain the situation a little better and tell us more precisely what you did during the rebuild. Just saying it makes a noise when I do "action x" isn't quite enough info.
Describe the noise, describe the situation in detail, and describe the maintenence that when into the rebuild.
sukhchimed (02-28-2015)
Thanks guys and my bad to enough explanation .try again to explain . So. I have changed all the sincro rings and bearrings and main shaft of gear box .there is a copper ring placed into engine crankshaft really out rear the gearbox mainshaft is goes in to it .,i think it s holds the mainshaft swing (controls ) every time gearbox makes noise that ring busted. So i thought something wrong with my gearbox .3 times i have changed tgat copper ring placed into crankshaft . And i opened the gearbox and changed the bearring of first mainshaft. It goes 2 or 3 month ok , and no noice.that noice is also is strange it doesnt make noice until i hit the cluts releace pedal and try to shift and give a little bit of gas it comes .and when i take off the pedal it is off .opening up gear box it really not noticeable someting is broken so i don.t know .kkkkk have you guys understand try to understand my bad english
I have had a look at the RAVE workshop manual for your problem. You need to download the manual (it's free here on this forum) as it's very useful for repairs and identifying parts to order.
The section you need starts at page 33-1-2 which is the TD5 clutch asembly and continues in the manual gearbox section for the R380 gearbox page 37.1 onwards. The bush you seem to have much trouble with in the end of the crankshaft is the gearbox input shaft spigot bush which is actually located in the end of the crankshaft. I cannot see why this keeps breaking as it only works when you change gear otherwise the clutch assembly is transferring the drive from the engine to the gearbox. If you have replaced the input shaft tapered roller bearing and it has been shimmed correctly there should be only very small movement on the input shaft. Is the input shaft spigot badly worn or grooved? as it should be a smooth running fit in the spigot bush without any noticeable slack.
The R380 is not the best gearbox produced by LR and does have issues. It might be a reasonable idea to get a spare gearbox and then very carefully renovate it amking sure the shafts and bearings all work and slide correctly and then change the gearboxes over. Also mke sure your clutch and clutch release bearing is in good condition including the pressure plate.
Unfortunately I have no experience of the R380 gearbox as mine are automatics so I'm at the limits of my general experience. The guys who use manual gearboxes are the Australians, it may be worth looking at the Aulro LR website
Australian Land Rover Owners
these guys are also LR enthusiasts and very helpful. Good luck and keep in touch.
jwittlock
02-20-2015 08:53 AM
MRDM1
03-16-2007 07:03 PM
