Help with 1138 code
Old Oct 20, 2008 | 05:29 PM
jairocol's Avatar
Default Help with 1138 code
Help, help, help.
Guys, I need your expertise and ideas on how I can cleared out the 1138 code from my Discovery 96 4.0 Lt with 90,000 miles.
I started working on clearing out " the check engine light " and after few repairs like newspark plugs, new cables and others .
the only oneleft is the 1138 code that means " engine sensor " Engine rich " codes" AD.
My mechanic says that we need to replaced the Sensor by the Passanger side.
He is not certified for Land rover cars, so I would like to learn from you is this is the right decision or we should try something else.
greetings from the windy city Chicago.
Jairocol
Old Oct 20, 2008 | 06:04 PM
Default RE: Help with 1138 code
What senor does he want to replace?
Old Oct 20, 2008 | 06:24 PM
jairocol's Avatar
Thank you for yor replay Spike555, I was picking up my high school kid and I took longer to came back. My mechanic wants to replace the sensor by the catalyzador because on his computer shows 1 H02 sensor banco "A" by the passander side.
Old Oct 20, 2008 | 07:14 PM
Ok, he is talking about the oxygen sensor, he needs to replace all of them at the same time.
How long ago did he replace the plug wires? On Discovories when the plug wires go bad it will set off a O2 sensor and or a to rich fault code.
Try and find out what plug wires he used and how long ago they were installed.
Old Oct 20, 2008 | 08:00 PM
jairocol's Avatar
We replaced the spark plug wires with the regular ones and I didn't place the magnaco 8mm wires, should I go for this before I try the oxygen sensors?
Thank you
Old Oct 20, 2008 | 08:05 PM
If he used Land Rover plug wires then your should be fine, if he used anything but Land Rover or Magnecor plug wires then yes, replace the plug wires first. They will be cheaper than O2's.
Old Oct 20, 2008 | 08:14 PM
jairocol's Avatar
we bought spark plug wires at a auto zone store and I asked for land rover wires and they gave me some blue wires for $40. Do you think these are correct?
Old Oct 20, 2008 | 08:25 PM
They sold you what you asked for, plug wires that will fit a Land Rover.
Order the Magnecor plug wires and then return the ones from AutoZone after you install the new ones.
Old Oct 21, 2008 | 07:23 AM
jairocol's Avatar
Thank you very much Spike555 for your help.
I am goingto try the Magnecorplug wires first. I let you know.
Greetings from Chicago
Old Oct 21, 2008 | 08:08 AM
www.atlanticbritish.com
All things that you need for your Rover.
