Help! 1st time disco owner . Random misfires.
Old Sep 24, 2019 | 12:08 PM
Jason Feuerstein's Avatar
Originally Posted by DiscoAntonio
Thanks for the input folks. So I just got around to checking the fuses and fuse number 2 was completely blown. I'm guessing badd grounding can cause fuse to blow or some other issue?
Sometimes they just get old. I always replace a fuse once before moving to diagnose a short.
Old Sep 24, 2019 | 12:21 PM
DiscoAntonio's Avatar
Looks like I'll be searching for a bad ground now. Under the hood as I type. Any suggestions on where to start. Mechanically and electrically I'm intermediate level
Old Sep 24, 2019 | 12:22 PM
That makes perfect sense. I'll replace it and go from there thanks a lot.. I'll post an update as soon as one is available
Old Sep 24, 2019 | 12:30 PM
Friday Night Disco's Avatar
Do not spend too much money till you find out what ECU you have
Old Sep 24, 2019 | 12:33 PM
Dave03S's Avatar
Can you not turn off SAI in the ECU with one of the more sophisticated scan tools?
Old Sep 24, 2019 | 01:20 PM
So I replaced fuse number 2 and now I only have the manufacturer codes and p0154 and p0340
Old Sep 24, 2019 | 01:22 PM
Acceleration a Tadd bit better but still not 100%. Any idea on how to tell the difference in the ECU units?
Old Sep 24, 2019 | 01:45 PM
Can you list the manufacturer codes you're getting? If you're still getting codes related to the SAI system, it's because you have an SAI-type ECU. If you can register your vehicle as historic, you should be fine with that ECU, but you'll never be able to pass inspection with the check engine light on.
P0154 is a dead O2 sensor. They're always good to replace anyway. Get either Bosch, NGK, or Denso.
P0340 is still a camshaft sensor malfunction.
As for acceleration, I'm not sure what you're expecting, but you shouldn't expect much. Even with the 4.6L, it's still a 4600 pound vehicle with 217 horsepower. The engine is much better at making noise than speed.
Old Sep 24, 2019 | 01:50 PM
Dave03S's Avatar
It should still take several drive cycles to reconstruct proper adaptive values. A properly running 4.6 has plenty of acceleration.
Old Sep 24, 2019 | 02:26 PM
P1300
p1319
p0340
p1590
p0154
