HELP! 2002 Disco SE Won't start
Old Feb 7, 2014 | 04:06 PM
Justin Chig Reagan's Avatar
7th Gear
Default HELP! 2002 Disco SE Won't start
It will crank and crank and crank, then if I give it gas it fires up and will run indefinitely as long as I'm giving it gas. As soon as I let off the gas, it dies immediately. The only thing I've been told is to clean the Idle Air Control Valve, which I plan on doing tomorrow. Any other ideas on what this could be? I have just replaced a month ago the fuel pump and the Crank Sensor, so those are good.
Old Feb 7, 2014 | 04:27 PM
Jared9220's Avatar
Do you have any trouble codes? Was it doing the same thing before the fuel pump and crank sensor? was it running fine after the new sensor and pump until recently?
1) Check for spark while someone cranks on the car
2) Make sure your throttle cable is adjusted correctly
3) try turning the key to the on position but don't start it. Let it sit for a few seconds and turn it off. Then back to the on position and wait a few seconds then off again. Then turn it to the on position a 3rd time and this time try to start it. Let me know if it fires up. Where did you buy your new pump?
Old Feb 7, 2014 | 04:29 PM
7th Gear
No, I can't get to a place that has a trouble code computer reader device nor do I have one. My vehicle is stuck at work.
Old Feb 7, 2014 | 04:43 PM
Jared9220's Avatar
I added a few things to my post above.
Old Feb 7, 2014 | 05:01 PM
7th Gear
Ok I will try that first. I got the pump from Shyi Co Rovers. It was a used, but tested part and I can hear it engage. I don't think that's the issue.
Old Feb 7, 2014 | 05:33 PM
sjfarbs's Avatar
Start at the top,car needs 3 things to start and stay running. Fuel, Air, Spark. Eliminate each one off the list and narrow down what system is at fault.
Old Feb 7, 2014 | 05:46 PM
MarkSF's Avatar
I have had the same issues, caused by an idle air control valve sticking.
Old Feb 7, 2014 | 07:56 PM
7th Gear
I tried the key turning and that did not work. This has happened a couple of times before and I fixed it by unplugging the negative terminal on the battery for a while and plugging it back in. That method obviously isn't working now.
Old Feb 7, 2014 | 08:00 PM
7th Gear
Did you have to replace it or were you able to clean it out?
Old Feb 7, 2014 | 08:03 PM
7th Gear
No this is a completely different set of symptoms than the fuel pump and crank sensor. It ran perfectly after replacing those. The key thing didn't work.
