Help
Help
I have a 2003 land rover discovery se7. periodically i have 3 lights that come on at the same time. the ABS, the TC and the hill descent light all flash amber and stay on until i shut off the engine. also the srs light does the same thing, but the first 3 come on at the exact same time. anyone have any ideas as to what is causing this?
Repairing Antilock Braking System Problems in the Discovery II
look up a ABS modulator shuttle valve repair kit,($64.95) Iteam number SWO500030 they often go bad and up to just latley you would of had to buy the hole ABS block wich would run you $1500.00.go to your local parts store and get them to run there code reader, I would start there, if not it will be more likley one of your abs sensors which are at each wheel.All these parts are easey to install, pritty much if you can do a brake job and change your oil you should be able to do these fixes your self. Good luck!
alti
03-13-2013 08:30 AM
Speed racer
10-11-2008 10:56 PM
