HELP!!! Brand new owner...
Old Mar 21, 2007 | 07:53 PM
kraftwyrk's Avatar
8th Gear
Default HELP!!! Brand new owner...
I have had my 2000 Disco for 4 days now...it has 88K on it..as I am driving home from work the car started rocking back and forth at stop lights and making a thumping sound when I stopped. It appears to be coming from the right front of the vehicle....I also noticed today for the first time the sloshing sound I have read about...
I have checked the items mentioned in the other posts and don't see fluid loss, have good pressure and no heater issues...could my thump and rocking be connected to some rare Rover issue ????
Old Mar 22, 2007 | 01:24 PM
Aquaholic's Avatar
Default RE: HELP!!! Brand new owner...
Were you pumping the brakes to make it rock back and forth?
Have you changed your brake fluid?
Old Mar 22, 2007 | 01:29 PM
kraftwyrk's Avatar
8th Gear
No, I was just coming to a stop at a light...I was going abot 10 MPH when it happen....
Old Mar 22, 2007 | 01:44 PM
Aquaholic's Avatar
Have you looked at your brake pads? Any large grooves on the discs?
Sounds like you may have worn through your pads, or perhaps contaminated them.
Is there an ABS light on? Perhaps the ABS system came on due to a faulty sensor.
Old Mar 22, 2007 | 01:56 PM
kraftwyrk's Avatar
8th Gear
No ABS light....
Old Mar 22, 2007 | 02:57 PM
kraftwyrk's Avatar
8th Gear
The fluid in the hydralic stabilizer was very low...I added fluid to the prescribed level...could this be part of the problem ?????
Old Mar 22, 2007 | 05:05 PM
Aquaholic's Avatar
Sounds like you have an HSE
That's above my pay grade - don't know anything about hydraulic stabilizers.
Old Mar 23, 2007 | 04:17 PM
ORIGINAL: kraftwyrk
What hydralic stabilizer?
Mike
Old Mar 23, 2007 | 04:21 PM
Are you sure your front drive shaft is not failing, they are know to have u-joint failures in the constant velocity joint which will also take out the tranny when it fails.
Mike
Old Mar 23, 2007 | 05:23 PM
variablecheese's Avatar
4wd High
Ouch...I had that happen on an old Cherokee I had. Spun the shaft right THROUGH the bell-housing. [>:]
