HELP!! Coolant flooding oil after Head gasket job
Hey guys,
2 days after doing a head gasket job (did it myself), car ran great, coolant stayed in expansion tank, and oil was dark. So, I changed the oil on day 3 evening, with Rotella T6 5W40 and Mobil 301 filter (long).
Next day (day 4), drove the car for about 12 miles and noticed the temp climbing, pulled-over shut car off for few mins. Checked and saw coolant in expansion tank was completely gone. Saw milky oil on dipstick, way past the max level. Added water to expansion tank, ran engine for few mins, no smoke from tail pipes, expansion tank empty again, milky oil much higher on dip stick. Called AAA and towed car home.
Day 5: drained and replaced milky oil, replaced oil filter, filled expansion tank with fresh coolant. Warmed car up on my drive way, then drove quarter of a mile. Again, all coolant gone from expansion tank, oil milky, and dip stick beyond max.
QUESTIONS- 1. Is my head gasket blown again? (after 3 days of replacement)
2. Do I have a cracked block (replace engine?)
3. Do I retrace my steps and re-install head gasket
4. What else could I check or replace to solve this problem
Thanks guys!
2003 Disco SE, 132k miles
Thanks guys!
Pardon me Mike, I guess you didn't quite get me. I'm not driving it, I only drove it after the 2nd oil change and coolant refill to confirm the situation. Drove only 1/4 mile. No, I didn't have this problem before replacing the head gasket. No, I didn't over heat- towed the car home. Yes, heads were pressure tested, and resurfaced at machine shop.
Perhaps not. While this one was external, you can see where there is a side that when failed can dump into oil.
Skip any torque (like second 90 degrees?) -
Re-used old bolts?
And could someone comment about additional torque of heads (if you skipped some) and if you could detect that with a torque wrench?
Re-used old bolts?
Re-used old bolts?
Re-used old bolts?
First thing before you suspect a bad head job or cracked block, remove the lower intake manifold and make sure you didn't kink it on reassemly. I did this on my hg job and I had coolant leaking into the oil. It passed a pressure test. Luckily I didn't drive it though I caught it. Exhaust all options before you get scared into buying a new block. Good luck!
