Help! Coolant leak
Old Feb 6, 2022 | 01:38 PM
Prichard's Avatar
7th Gear
It's 10* outside now so I don't plan on checking the tightness at the moment but will when it warms up a bit and check above and see if it's magically leaking from there. I did use Permatex Thread sealant High temp 59214 on those that go through. Maybe I didn't use enough, or maybe it was too cold to seal properly?
Here's what I used. Permatex Thread Sealant
Old Feb 6, 2022 | 01:42 PM
Richard Gallant's Avatar
You may not have used a enough I tend to cover all the threads in through bolts,
Old Feb 6, 2022 | 05:56 PM
JohnZo's Avatar
That thread sealer is the same stuff I used and it worked. Coverage was same as RG above. The bolt hole needs to be very clean too.
Old Feb 7, 2022 | 06:33 AM
Extinct's Avatar
Regular black silicone works just fine, use liberally.
BoulderCO
Jan 20, 2022 02:18 PM
BS50MGSXR
Aug 10, 2021 01:07 AM
WildPackofFamilyDogs
Apr 29, 2021 04:50 PM
BajaXJ92
Feb 5, 2010 08:10 PM
lipadj46
Jul 9, 2009 04:03 PM
