Help in Dayton Area
Old Apr 17, 2011 | 09:53 PM
grodrianst's Avatar
8th Gear
Default Help in Dayton Area
Hey Guys, so I'm back in the States and have started working on my '02 Disco that my wife bought while I was gone. It's in fairly decent shape, needs some small things and a couple big ones. I rebuilt the driveshaft this weekend thanks to the write-ups here. It looks like I have a pretty good oil leak. My wife took it to the Nashville dealer before I got home, they supposedly put dye in it but couldn't pinpoint a leak said, "it's coming out all over" so they want to do the heads for $2600.00. I'm a decent shadetree mechanic and from what I've read here think I can do it. I will be taking it back up to Dayton OH, where I'm stationed, before starting and my question is for anyone around that area. I'll be looking for any good shops to help with this project and anything else that comes up. Thank you in advance for the help.
Stan
Old Apr 18, 2011 | 06:54 AM
Bundu's Avatar
Banned
I would start with tightening up the valve covers, they are the #1 spot to leak. Clean the engine and then figure out where it's leaking from. Don't do the head gaskets unless you really need to. Other oil leak spots are the valley gasket, front cover gasket, front & rear crank oil seal, oil pressure sensor, oil cooler hoses (need o rings), oil pan gasket.
Old Apr 18, 2011 | 09:39 AM
dcarr1971's Avatar
I think the guys from GreenOvalGuild.com or the Miami Valley LR Society are your local Rover clubs/groups. I'd suggest touching base with them to see if they can recommend a good local shop...
Old Apr 18, 2011 | 06:58 PM
armored's Avatar
Stan, Where in the Dayton area are you? I'm in Bellbrook if you want me to try to help you out. I work over on Springfield St right down from the base. PM me your number and we can take a look. I've got an '03 that Ive done HG on and an '01 that I'm getting ready to do.
Old Apr 18, 2011 | 07:10 PM
grodrianst's Avatar
8th Gear
Wink
Thanks guys. Bundu, I actually bought a dye kit the other day before I made my post and was going to try to pinpoint a little better where it's leaking from. What's interesting is, the top half of the engine appears clean so I am trying to diagnose it a little better before tearing into it. From what you said I guess the heads shouldn't be done just to prevent a blow-out? I was kind of thinking from everything that I've read here that they will blow eventually and chances are I'll drop a cylinder liner. So I was thinking maybe I should just get it done and hopefully get another 100k out of it...
m3dragon
Jan 21, 2015 10:49 PM
kevin7723
May 30, 2013 09:01 AM
Dan7
Jan 19, 2013 05:45 PM
Binky
Mar 7, 2011 12:49 PM
Aj6543
Nov 27, 2009 09:27 PM
