Help Diagnosing Oil Leak
The White Shepard is supposed to expand and recondition rubber seals. If you get a bottle its $19.99. You must drive the car for at least 30min when pouring in the White Shepard.
Lucus Oil Stop leak is THICK like molasses. It seems to slow leaks down too. $14.99 a quart. I think you add 1/2 to 3/4 of a bottle to 6 quarts of oil. Those do work but you need to add them at each oil change which gets pricy.
After replacing the oil pan gasket and crank seal. I dont need any of the additives. I have a very slow leak with one drop always on the front of the oil pan. It probably the front cover seal. I'd rather leave the rock unturned till it gets worse.
CodyG
09-18-2012 06:35 AM
iceray111
05-15-2010 02:40 PM
