Help Diagnosing Oil Leak
Old Aug 28, 2011 | 11:44 AM
bosshogt's Avatar
Originally Posted by disc oh no
Instead of white Shepard, would a decent "high mileage" oil help with this?
I have used Mobil 1 high mileage 10w-40 and it has more wear protection built into the oil. Its not a leak stop. As the other guy said above this. I am too will be switch over to Shell Rotella 15w-40 on the next oil change. My car seems to have a higher oil pressure with the 15w in hotter whether. I have a digital oil pressure gauge and keep my eyes glued to it. I like to see my oil pressure at 8-12psi at hot idle. The 10w Mobil 1 is to thin it seems here in Indiana on 95 degree days.
The White Shepard is supposed to expand and recondition rubber seals. If you get a bottle its $19.99. You must drive the car for at least 30min when pouring in the White Shepard.
Lucus Oil Stop leak is THICK like molasses. It seems to slow leaks down too. $14.99 a quart. I think you add 1/2 to 3/4 of a bottle to 6 quarts of oil. Those do work but you need to add them at each oil change which gets pricy.
After replacing the oil pan gasket and crank seal. I dont need any of the additives. I have a very slow leak with one drop always on the front of the oil pan. It probably the front cover seal. I'd rather leave the rock unturned till it gets worse.
moparrebellion
Jun 11, 2010 12:19 AM
iceray111
May 15, 2010 02:40 PM
kae
Feb 23, 2010 08:37 AM
MCA
Oct 4, 2006 01:45 PM
