Help, drowning in coolant and cat litter!
Well I completed my head job. All went well. Idled and sounded great for 10 minutes. Talking with my dad on the phone and he says, flip on the heater. I did and Boom. radiator fluid everywhere. Well I found the o-ring on the coolant pipe going into the intake was busted. So I have radiator fluid all over the intake gasket. Did I ruin it or should i just throw the o-ring on the coolant pipe and move on?
Well i completed the head job with no problems. Ran it for ten minutes, smoking a little bit, but puring like a kitten. Flip on the heater and fluid dumps all over the floor. The o-ring on the coolant pipe that goes into the intake manifold was torn. So fluid dumped on the intake gasket and ran to the back of the motor and dumped to the ground. So besides the o-ring do I need to go back and replace the intake gasket? Thanks folks.
Nope. Just the O-ring. When I changed my valve cover gaskets the other week, I started it up afterwards to check for oil leaks, and to my horror saw coolant ppouring from the back of the engine. I thought I had somehow jacked up the manifold gasket. It was just the coolant pipe O-ring leaking and filling the recess of the intake in which it fits. When that filled, it drained onto the valley pan and ran to the back of the engine.
I had even replaced that O-ring with one from my work at a parts store based off a pipe from an old engine. It was maybe 1/32" too big and rolled during pipe fitment. I ordered a new O-ring (from a proper supplier) and was good to go after replacing it.
I too had trouble with that O-ring after my head gasket job several years ago. I think I went through two or three before I got it installed without tearing. I applied a thin layer of lube on it after I put it on the pipe and before pressing it into the manifold. Anything will do - grease, motor oil, butter or margarine. Just something to ease it in.
aguison
11-18-2012 05:15 PM
elboy0712
12-19-2010 02:48 PM
