HELP!!! Firing Order
OK...swapped out the old plug wires with the Magnacore wires and I think I mixed one up. It will run...but has a little skip down in the low RPM range. Can someone give me a firing order diagram?
2004 Disco. Two coil packs. As detailed as possible please. 4 across the top, 4 across the bottom, then left and right cyclinder banks. Please clarify if the diagram is looking at the engine (ie: drivers side right) or the standard left drivers side.
Please help asap!
Jeff
Please help asap!
Jeff
Excellent! I will go out and try right now!
One more question......
On the drivers side firewall, near the brake booster, there are a series of hard plastic lines attached to the firewall. The bottom one isn't attached to anything when it comes out from the side towards the engine. I don't know if I knocked something off or if it is supposed to be that way. I can't see any loose hoses anywhere.
Whew! Thanks guys. I didn't think I nudged anything but it was tight quarters getting those wires off. One boot was cracked which I assume was the reason for my sporadic mis-fire (mostly when it rained).
Getting my 6"2" 240lbs frame up under that hood and getting my hands down there was not easy! I actually used a long aluminum tube (a rear fender support for my Meyers Manx dunebuggy, to get down there and pry the old ones off.
