Help identify Mystery Plug
Old Jul 10, 2015 | 05:15 PM
chicane's Avatar
Question Help identify Mystery Plug
I noticed while under the passenger side of the truck I had this plug that wasn't plugged into anything and nothing close to plug into and to cover. it is directly under the passenger compartment running parallel with the passenger side rocker. Any ideas?
Old Jul 10, 2015 | 05:22 PM
Racer X's Avatar
I believe it's for the electronic air suspension on vehicles equipped with the option.
Old Jul 10, 2015 | 06:09 PM
drowssap's Avatar
There is a sensor there one of my trucks i think it is the one with ACE.
Old Jul 10, 2015 | 07:29 PM
It was not for the SLS system, all that wiring was under the drivers seat on the frame. As for the ACE, if the vehicle had ACE, it would have had connections under the passenger seat located by the frame, so I can't tell you what it is for.
Old Jul 10, 2015 | 09:31 PM
chicane's Avatar
Exclamation
I do not have SLS or ACE is this pre-wiring for one of those systems? I'm just worried that I have a missing sensor.
Old Jul 11, 2015 | 06:28 AM
disc oh no's Avatar
If you don't have any trouble codes for anything, you're not missing a sensor. My truck has a plug near the transmission that goes to nothing. If there's no problem with the truck, I wouldn't worry about it. I see this sort of thing on all sorts of vehicles.
Old Jul 11, 2015 | 07:21 AM
chicane's Avatar
I do have a recurring code.
Old Jul 11, 2015 | 02:03 PM
Alphamale's Avatar
If you had had ACE the car would have had, lower and upper Accelerometers which are two of the ACE system components. The upper one would have been located behind the front interior light and the lower just about the front passenger (US) side outrigger, just where that unused plug is.
Old Jul 12, 2015 | 09:58 AM
chicane's Avatar
I just said no ACE.
Old Jul 12, 2015 | 01:24 PM
Alphamale's Avatar
I KNOW YOU SAID NO ACE , if you read what I said again, I said that if you had had ACE, you would have had an accelerometer that that plug connected to. As you don't have ACE the plug is therefore redundant, OK.
