Was under the hood of my 03 Discovery and noticed a broken wire connector on what appears to be a positive power wire for an accessory (?) connected to the positive battery terminal. Attaching some pictures. Assume this goes back to the fuse box as it routes back behind the engine, but haven't followed it all the way back yet.
Is any one familiar with this type of connection? Want to make sure I get the right spec. This (on the left) is where the wire attaches to positive post
You can see either side of the broken plastic connector
It's definitely not anything from the factory. If you have traced it, and it ends where are you show I would just remove it. It's doing nothing for you as it is, and that loose, positive wire behind your engine can only do harm.
