Help M A P sensor location 2004 disco 2
Old Jul 12, 2021 | 10:39 AM
Maxwell_land's Avatar
Default Help M A P sensor location 2004 disco 2
I can't find the location of the map sensor or manifold absolute pressure sensor everything I google comes up with the maf sensor or mass air flow sensor my disco is running lean and burning alot of fuel
Old Jul 12, 2021 | 11:02 AM
robertf's Avatar
Its by the dipstick if its a td5. Doesnt exist on a v8
Old Jul 12, 2021 | 11:10 AM
It is the V8 but I got a code for the map that makes no sense and also for my O2 sensor's I guess I just need to start going down the line then
Old Jul 12, 2021 | 11:45 AM
How does it know the fuel air mixture to use?
Old Jul 12, 2021 | 11:51 AM
nashvegas's Avatar
Are you sure you don't mean the MAF? It's all in there -- the big thing by the airbox in the intake tube. In other words, why are you looking for a MAP sensor (code or something ?)
I see MAP and MAF commonly confused on car forums etc online lots so perhaps you are looking for the MAF?
Old Jul 12, 2021 | 11:58 AM
Yeah I'm sure that's what the code came up with cause I've tested the MAF it was easy to locate but the codes are coming up with 1/2 O2 sensor's vac leak and Map sensor fault I checked for vac leaks with starter fluid nothing then i talked to friend and hes said the map can cause false readings for the o2 and vac leaks but I can't find it
Old Jul 12, 2021 | 01:15 PM
mollusc's Avatar
The V8 doesn't have a MAP sensor.
What are the codes that you're reading?
Old Jul 12, 2021 | 02:49 PM
P1174 p1412 p1129 this is what came up this time
Old Jul 12, 2021 | 03:14 PM
Best4x4's Avatar
P1412 = SAI (probably a vacuum line leaking, a 90 nipple cracked, or the little solenoid is INOP.
Old Jul 12, 2021 | 03:32 PM
I sprayed vac line with starter fluid to try and find a leak but rpms didn't rise maybe the cylinoid needs to be replaced
