Help me ID this leak
Old Jun 19, 2020 | 10:58 AM
davidpx858's Avatar
Default Help me ID this leak
good morning, i noticed a few small spots in my driveway and found below leaks coming from the rear seal. any suggestions on how to tackle this problem? or should i just keep checking the oil level? the last owner said he never notice any leaks, however, i park my truck in the drive way (sloped) not sure if that has anything to do with it.
also, anyone tried white shepherd/blue devil rear main seal ? do you think it might help?
thanks,
Old Jun 19, 2020 | 11:23 AM
HuskerRover's Avatar
Main seal or crucifix seals. Possible oil pan gasket, but doubtful. Blue Devil works well. I have a small seepage and was not willing to seperate the engine for the rear main for what amounted to 1mm spot. Can of BD swelled up the seal and good to go. and I am not a typical user of those "fixes".
Old Jun 19, 2020 | 11:30 AM
davidpx858's Avatar
thanks, can you point me to which blue devil product to order? there are a few...
Amazon Amazon
Old Jun 19, 2020 | 11:31 AM
davidpx858's Avatar
this one?
Old Jun 19, 2020 | 05:25 PM
Extinct's Avatar
Start with the PCV mod first, see if that addresses it. After that, tighten the outside valve cover bolts. If it is still leaking after that I would live with it. You can do the crucifix seals, but it the leak rate is slow I don't really think it is worth it.
Old Jun 19, 2020 | 06:32 PM
The Deputy's Avatar
Did you change oil lately? What viscosity did you use?
Oil leaks can be a basta*d to trackdown sometimes. In that area, it could be valve cover gaskets, valley pan, oil pan or rear main.
Old Jun 19, 2020 | 07:29 PM
rhyslegge's Avatar
That leak that you see all the way down at the bellhousing bottom, I had the exact same issue after dropping my oil pan and changing bearings. It turned out that oil was coming out of the valve cover gaskets and running down the block. Top valve cover gasket bolts were totally loose. Good place to start, although you will need to pull the upper intake.
Old Jun 20, 2020 | 10:12 PM
davidpx858's Avatar
i did..i just checked the dip stick and noticed the oil level is about 2inches above the FULL mark. could this be the reason? should i just drain it and refill? oil change was done by a shop
davidpx858's Avatar
Old Jun 20, 2020 | 11:18 PM
redwhitekat's Avatar
have you done this first ?????? If not your going to go in circles.
This is your first priority
