HELP... NOT STARTING!!!
RE: HELP... NOT STARTING!!!
I had a similar problem a few weeks ago. The battery was fine. The alt. was fine. The engine would turn, but it would not start. It turned out to be the crank position sensor. About an $80 part, if I recall correctly. Not too difficult to install. I have not had any problems since then.
Good luck.
Good luck.
on
1 Post
ORIGINAL: LRDKW
is there a different name for "Crank Position Sensor"... I searched my Workshop Manual and could not find it.
Buy it here http://www.innerauto.com/store/?N=16...ition%20Sensor At least for the 4.6
Pic of what it is...
Can we assume that you have not had any past problems with starting it and that you have not done any workwhat so everon the truck since the last time it was running (i.e. replacedspark plug wires or fuel filter, etc...?) You canget a code reader for about $30 or rent one for free from a parts store (you have to leave a big deposit usually). I'm very glad I bought one.
