HELP... NOT STARTING!!!
Old 02-05-2008 | 04:04 PM
okdiscoguy's Avatar
Default RE: HELP... NOT STARTING!!!
yeah, I agree. You need to figure out why it won't start. If you have been running with your CEL on and suddenly, it won't start, it could be a number of things. Just because someone replaced the sensor once and it worked, doesn't mean yours will be fixed. You are going to bea little upset if you change it (bi@#*&%tch to get to) and you still have to buy a $200 fuel pump.
Start with the basics and give up some more info, or you are just throwing money around, in which case, you should just take it to the dealer.
Was your CEL on before it died? >> rent a scanner, turn the key on and get back on here with all of the codes.
Do you have spark when cranking? >>use the old screwdriver method...
Do you have fuel pressure? >>Test at the fuel rail.... looks like a tire valve..
lazerbrains
LR2
38
08-09-2023 07:54 PM
fastrx7man
08-08-2010 11:04 PM
Rusty001
07-31-2009 07:58 PM
baby0411
01-30-2007 10:42 AM
readdiscovery
07-07-2006 05:23 PM
Quick Reply: HELP... NOT STARTING!!!
