HELP: Oil pan removal at a hault
So I took off the um-teen bolts to drop the pan...no problem. Now the cross-member is next but the 10mm bolts are rounding out. Yes, I used PB blaster and 6-pt sockets. So does anyone know a trick to getting the cross-member out, or can I remove the track bar instead? Seems to be held on by a 18mm bolt and some sort of torx bit on the bottom of the threaded post???
You don't need to take the cross member off, so do what zerhoom said, to remove the pan; that is all that is needed off.
Re thread the nut on the track bar.. smack the hell out of it. It will pop out. Just be careful. You really should take the pan down to inspect it. I did.. gave it a good cleaning also. Found 1/8 inch of goo in the bottom.
BFH can be your good friend.
