help p1230!!
Old Jun 30, 2012 | 07:49 PM
30more's Avatar
Default help p1230!!
Got in my trunk to more it amd it started and died.... now it giving me p1230 code? i tried to jump the relay to the fuel pump and it tried to start and died.where do i go now?
any help
thanks
Old Jun 30, 2012 | 08:12 PM
Fuel pump relay malfunction, time for a new one.
Old Jun 30, 2012 | 08:58 PM
30more's Avatar
just swapped my relays still no start
Old Jun 30, 2012 | 10:42 PM
30more's Avatar
just get a p1668
Old Jul 1, 2012 | 08:23 AM
What did you swap from, probably wasn't a fuel pump relay replacement.
As for the 1668, you now have a engine anti-theft circuit high signal.
Old Jul 1, 2012 | 09:30 AM
jafir's Avatar
Originally Posted by 30more
just get a p1668
That code can come from the battery being unhooked. If everything works ok, you can clear it and not worry about it. If you have weird issues with the thing starting and then immediately dying, then worry about it. (but in this case you've got something weird going on with the P1230).
See this link for the Land Rover / Bosch ECU manuals that Savannah Buzz found for us. In part 3, on page 90 it describes the P1230 fault you are getting.
https://landroverforums.com/forum/di...manuals-48009/
Old Jul 1, 2012 | 10:05 AM
30more's Avatar
It's my fuel pump I got power at the pump just not working
Old Jul 1, 2012 | 10:08 AM
How did you test it and what voltages did you get? I would still rather see you go get a fuel pump relay, cause there are no other relays in the engine compartment that you can switch out with and have the pump work.
jafir's Avatar
That makes sense... the manual shows that code meaning "open circuit" which if the pump is burned up or something would show up that way.
Old Jul 1, 2012 | 12:31 PM
30more's Avatar
I tested it with a test light. Should I use my voltmeter or go get a relay. Am I wrong to say it's the fuel pump since I had power there
