Help with Part Name
Old May 27, 2019 | 07:22 PM
bjordan's Avatar
Default Help with Part Name
Hi Folks,
My mechanic friend and I got the head gaskets replaced on the new to me (three weeks now...) 2002 Discovery. Once the coolant system built up pressure, we discovered another leak that was not there before, since with blown head gaskets, neither of us drove it enough to get the system up to pressure. Now there is a leak, at the back of the engine, on the passenger side. My mechanic is calling the leak at the "heater bypass hose" and it needs to be replaced. Can someone tell me what this part is, by name and maybe a picture/listing of one one Ebay?
Thanks, as always - we are closer o getting this Rover out on a real test drive.
Old May 27, 2019 | 07:53 PM
Red5's Avatar
Probably means this. PCH500040
Several on Ebay or the Rover specific sites.
Old May 27, 2019 | 08:15 PM
bjordan's Avatar
Originally Posted by Red5
Probably means this. PH500040
Thanks Red5. Can you double check the part number? Its not coming up on ebay, or on google. Or, if you dont mind, paste in on e of the listings from ebay. Thanks.
Old May 27, 2019 | 08:33 PM
KernowDiscovery's Avatar
https://www.ebay.com/p/Land-Rover-PC...d=254111808860
Old May 27, 2019 | 08:37 PM
Red5's Avatar
Sorry, fixed it. It's PCH
Old May 27, 2019 | 09:04 PM
mln01's Avatar
What is PCH?
Old May 27, 2019 | 09:23 PM
Originally Posted by mln01
What is PCH?
A 'Pricey' Coolant Hose.....
Old May 27, 2019 | 09:31 PM
Best4x4's Avatar
I just use 5/8 Heater Hose & cut it to fit. Works great and it's cheap!
Old May 28, 2019 | 04:39 AM
JUKE179r's Avatar
This!
You can also install the fancy clear 5/8" coolant hoses to pimp out your engine. lol
Old May 28, 2019 | 08:19 AM
bjordan's Avatar
Thanks for all the replies folks.
So, I sent a pic of PCH500040 last night to my friend, and that isn't the busted hose. I found an entire kit of hoses on ebay and I will send him a picture of that and see if one of those hoses is the correct hose that is leaking. I know its not a simple 5/8" heater hose, although I wasn't under the truck when he saw what was leaking, so I can describe it. We'll get it figured out. We are still fixing issues that came with the truck from the PO, including a weeping rubber freeze plug and an exhaust leak that we discovered yesterday.
