Help with parts for my new 04 D2
Old Sep 23, 2010 | 03:06 AM
pennohawk's Avatar
Default Help with parts for my new 04 D2
Thanks to all the regular posters out there, this forum is an incredible resource. Although I have found out I have a lot of work to do! I picked up an 04 D2 at the beginning of the summer with 70k on it, recently it has started running a bit rough and the SES light came on. After reading the forum I am now going to refurb my front driveshaft with parts from Advance Auto, install Wix air filter, Bosch 4+ and Magnecor wires. I am also going to replace my O2 sensors and here is my question, there is such a price difference in parts out there, has anyone tried these? They seem too cheap to be true:
eBay - $22 O2 Sensors
Also someone mentioned that the front and back are different, is that true for the 04 D2?
I am also thinking of getting a Scanguage 2, it is a bit pricey, anyone have one that likes or dislikes it, is it worth the $$?
I also have to replace my fuel door release solenoid, anyone have any tips on getting at it?
Lastly, is it worth installing the Volo chip, does it affect performance to increase mileage?
Thanks again for all the great posts, I am excited about getting to know my D2 a little more intimately.
Old Sep 23, 2010 | 05:12 AM
hilltoppersx's Avatar
yes too good. they are just universals not really for you truck.
yes.
http://www.roverparts.com/Parts/MHK100920.cfm
http://www.roverparts.com/Parts/MHK100930.cfm
i like it because i can keep a close eye on my MPG and coolant temp. it won't give you certain things like oil pressure or fuel pressure.
are you sure the actuator is bad?
someone on this forum was running that chip. personally i have other things to tackle considering its not my DD its not that big of a deal.
Old Sep 23, 2010 | 06:43 AM
souljad9's Avatar
Whats wrong with the fuel door? Will it not open, or will it not stay closed?
Old Sep 23, 2010 | 06:49 AM
Bundu's Avatar
Banned
Have a look at the Ultragauge www.ultra-gauge.com
Try clean and lube your fuel door latch.
Old Sep 23, 2010 | 07:35 AM
antichrist's Avatar
The cheapest place I've found for OEM o2 sensors is Amazon, believe it or not. Pre and post cat are different.
I like the Kingsborne wires, 1/2 the price of Magnecore and just as good from what I can tell.
Old Sep 23, 2010 | 08:30 AM
Same can be said for a good scanner, don't waste a bunch of money on a scan gauge when you can buy a good scanner on Amazon like I did last year, bought a 3130 that retails for over $300 for $134 on Amazon and will blow a scan gauge away in features.
As for the 02's, go to British Parts of Utah for parts like that, or as Tom mentioned Amazon, do not buy universal 02 sets, they are junk.
Old Sep 23, 2010 | 10:06 PM
oysterhead's Avatar
Mike do you know if the 3150 can read ABS codes on our vehicles?
Old Sep 23, 2010 | 11:28 PM
bosshogt's Avatar
ScanGuageII
I have a ScanGuageII and like it a lot. First the LCD can be changed to green to match your night instrument cluster lights. It gives you the function to monitor 4 instantaneous gauges at the same time. It will read all check engine lite codes. And give you the 4 digit code number. The largest advantage I see to the ScanGuageII is the water temp guage. Along with the air intake temp, which gives me an idea of under hood temp, because I have a cold air intake.
ABS Amigo
ABS codes are proprietary by all car manufactures. So no off the shelf OBDII scanner can read them. That is why you have to go to a shop with a Hawkeye or the dealer or order the ABS Amigo. I got mine and I will figure it out soon.
Volo Chip.
I have had my Volo Chip installed now for about 2000 miles. I would say I get 14.5mpg in the city and 17-19mpg on the highway if i keep it under 75mpg. It does take 700 miles to start to work
Old Sep 25, 2010 | 05:04 PM
pennohawk's Avatar
Bundu,
Do you have an Ultra-Gauge? How do you like it?
Thanks
Old Sep 25, 2010 | 05:08 PM
pennohawk's Avatar
Hilltoppersx, Souljad9, Bundu,
RE: Fuel door solenoid:
I checked the fuse and swapped the dash switch out for one that works in my buddy's rig, I think all that is left is the solenoid. When you hit the switch it makes no noise.
I could try and clean/lube it, but I would think you would hear something if it was trying to actuate the pin but the pin was stuck. It was stuck closed originally but I jimmied it open and put some tape on it so it does not close again until I fix it.
Thanks for the help
