Help Please
Help Please
Hi guys,
How is the thermostat hooked up to the radiator/pump hoses? Does the straight part on top go to the water pump? Rave appears to have it that way. Just checking. I replaced my thermostat for a 180 degree one, and I am actually running warmer after the install. Everything has been bled properly. Thanks for the help.
Looking at rave, the angled connection on top of the tstat seems to go to the water pumpand the straight hose connection goes to the upper radiator hose. But checking the diagram on rovers north website (Land Rover Discovery II Cooling & Heating Parts Available from RoversNorth.com) it appears to be the opposite. Any clarification is much appreciated as I do not want to fry my truck. Thanks.
Before changing tstats I could cruise around 188-192. Now I am in the 204-207 range. I thought maybe I had hooked the tstat up incorrectly, but that is not the case. Also, I had bypassed the throttle heater plate with a hose directly to the reservoir. That just burst. I'm taking this tstat out immediately.
I would replace the t body heater plate instead of the bypass. I had a very small leak coming form there my temps were climbing a little higher and higher then bought the Atlantic British replacement put it on and my temps then stabilized. Pretty crazy what a little leak will do.
Your very welcome, i understand on the t-body plate bypass i paid $21.95 for mine new gasket new bolts and the plate of course.
Well, I replaced the bypass hose. Topped off the coolant and started the bleeding procedure. The temp hit 200 so I shut it down. Swapped out the 180 tstat for oem. After bleeding the system I drove around a bit. Temps didn't get over 195, as usual. I guess the seller Sent me a defective tstat.
