Help Please
Old Sep 5, 2012 | 01:18 PM
willrok13's Avatar
Default Help Please
Hi guys,
How is the thermostat hooked up to the radiator/pump hoses? Does the straight part on top go to the water pump? Rave appears to have it that way. Just checking. I replaced my thermostat for a 180 degree one, and I am actually running warmer after the install. Everything has been bled properly. Thanks for the help.
Old Sep 5, 2012 | 01:37 PM
willrok13's Avatar
Looking at rave, the angled connection on top of the tstat seems to go to the water pumpand the straight hose connection goes to the upper radiator hose. But checking the diagram on rovers north website (Land Rover Discovery II Cooling & Heating Parts Available from RoversNorth.com) it appears to be the opposite. Any clarification is much appreciated as I do not want to fry my truck. Thanks.
Old Sep 5, 2012 | 01:45 PM
lr2001silver's Avatar
Banned
Bottom port goes to lower radiator hose.
Top long port goes to the upper hose that runs into the T.
Top side port goes to curved hose that goes towards the bottom.
Hope this makes sense.
Old Sep 5, 2012 | 01:55 PM
coors's Avatar
How do you know you're running warmer? What are your temps?
Old Sep 5, 2012 | 02:23 PM
willrok13's Avatar
Before changing tstats I could cruise around 188-192. Now I am in the 204-207 range. I thought maybe I had hooked the tstat up incorrectly, but that is not the case. Also, I had bypassed the throttle heater plate with a hose directly to the reservoir. That just burst. I'm taking this tstat out immediately.
Old Sep 5, 2012 | 02:27 PM
willrok13's Avatar
Also, while bleeding the cooling system I noticed my temps climb entirely too fast. Where I used to have to idle the truck for 10 mins or so to get it to temp before replacing the reservoir cap, I hit 188 in about half that time. And the idle temp will keep climbing to around 200.
Old Sep 5, 2012 | 02:30 PM
Banned
I would replace the t body heater plate instead of the bypass. I had a very small leak coming form there my temps were climbing a little higher and higher then bought the Atlantic British replacement put it on and my temps then stabilized. Pretty crazy what a little leak will do.
Old Sep 5, 2012 | 02:33 PM
willrok13's Avatar
Thanks for the help. I bypassed it two years ago while doing the head gaskets. Been stable for that long. The only thing that's changed is this stupid tstat. I need to get the truck drivable. Cant get the heater plate hoses that quickly.
Old Sep 5, 2012 | 02:55 PM
Banned
Your very welcome, i understand on the t-body plate bypass i paid $21.95 for mine new gasket new bolts and the plate of course.
Old Sep 5, 2012 | 03:28 PM
willrok13's Avatar
Well, I replaced the bypass hose. Topped off the coolant and started the bleeding procedure. The temp hit 200 so I shut it down. Swapped out the 180 tstat for oem. After bleeding the system I drove around a bit. Temps didn't get over 195, as usual. I guess the seller Sent me a defective tstat.
