Help please, im new here, but not to discos. looking for advice
Old Apr 20, 2010 | 08:02 PM
RWM3's Avatar
Default Help please, im new here, but not to discos. looking for advice
whats up, i have a 99' disco II stock. i ordered a brushbar and some new lights, but want to raise her up about 2 inches total, and then get some mud tires. idont know much about tires at all so i just want to know what to get. i want something in the 32" rage that arent terribly expensive.
as for the lift, idk whether i should go with body, suspension, or a combination of both. im really looking for straight up ground clearance, so whichever is best.
posting links would be amazing thanks guys
Old Apr 20, 2010 | 08:35 PM
The whole purpose of a lift is to allow space for bigger tires.
A lift does nothing for ground clearance but it does help approach and departure angles.
Your ground clearance is only as high as your lowest point, and thats your differentials.
You will want a suspension only lift.
Old Man Emu is the preferred but also the most expensive.
Old May 13, 2010 | 10:37 PM
RWM3's Avatar
ok ive been looking around and that suspension lift sounds good. where is the best place to get it though? link?
Old May 13, 2010 | 10:52 PM
NiteTrain's Avatar
if you just want the bigger tire look but dont plan to go off-road I suggest getting all terrain tires instead of mud terrain..they'll ride a lot better and do better in that NY snow.
Old May 14, 2010 | 06:36 AM
kenk's Avatar
http://www.rovertym.com/
http://www.ntwonline.com/WILD_COUNTR...ILE_P17022.cfm
http://www.lucky8llc.com/Index.asp
The tires are not brand name- but you are not gonna find an aggresive tire that cheap anywhere
Old May 14, 2010 | 12:39 PM
salve7's Avatar
Lucky8 did have free shipping on their OME packages FYI...
Old May 14, 2010 | 01:25 PM
Camdisco24's Avatar
Do you need a lift, or do you just want one?
I usually tell people to hit the trails a few times to determine what you really need.
You might find a nice A/t will do the trick.
If you're just going for looks, go for suspension as others mentioned. Body lifts dont go over well this our high profile trucks.
Old May 16, 2010 | 05:17 PM
RWM3's Avatar
no i legitimatly need a lift, if you look at my pictures, you can see that my tires are great all around (forteras) i just always get ****ed in deep ruts and departure angles. i really could use the lift and bigger tires once i can get some more money together, but ill check those links out, thanks!
Old May 16, 2010 | 06:44 PM
Camdisco24's Avatar
Well, you've determined what you need, and it sounds like you def. need a lift.
I saw the broken bumper pics, did you get that fixed already or are you just living with it for now?
Old Sep 3, 2010 | 01:20 AM
RWM3's Avatar
forgot about this thread. i got a new bumper from roverparts.com which was nice because i drove 20 min to pick it up at the warehouse! that was annoying to install because i destroyed the latches to fasten the bumper to truck. however, im not going to do a lift just yet. my tires are getting to the end of theyre life so im going to get some bil ol tires, maybe 34" or so and im going to to a brushbar and a custom roof bar and mount 4 lights.
legume
Aug 21, 2013 04:46 PM
BlueGreyBuilder
Jul 20, 2012 10:10 AM
Analogkid
Nov 11, 2010 05:31 PM
KBAR-04
Mar 1, 2009 01:26 PM
piotrsuw
Mar 9, 2007 06:31 PM
