Help removing the steering wheel
Hey guys I need someone to tell me what I'm doing wrong here. I need to remove the steering wheel to remove my dash board and I have followed the RAVE step for step and the damn thing isn't budging.
I have the necessary nut and screws removed, my wheels are straight and the steering wheel is straight but it is not moving one bit
Any suggestions?
Any suggestions?
Sit in the drivers seat, Nut removed, take your fists and alternate hitting the wheel at 9 oclock with your left hand, and 3 oclock with your right hand, as quickly as possible.What you are trying to achieve is a harmonic in the shaft to loosen it up. And remember to tape down the clock spring to keep it from moving while the steering wheel is off. Good Luck
