Help. Shifting out of park
Old Feb 22, 2020 | 04:37 PM
zuke's Avatar
Default Help. Shifting out of park
I replaced the ignition switch and now she won't shift out of park. I can push the pin and get it but I need to know if an electrical fault is causing a problem
Old Feb 22, 2020 | 04:51 PM
Red5's Avatar
Was it working fine before you changed the ignition? Check the brake switch. Do the brake lights come on when you press the pedal?
Old Feb 22, 2020 | 04:59 PM
zuke's Avatar
Yes they do. All was fine before
Old Feb 22, 2020 | 05:29 PM
zuke's Avatar
Screw it. I just yanked the solenoid
Russ Collins
Nov 23, 2018 03:55 PM
NMAZE
Jun 21, 2018 06:44 PM
bigred2929
Aug 6, 2015 09:58 PM
jeffmcdaniel
Feb 15, 2014 02:31 PM
JasonKramer33
May 2, 2006 05:30 PM
