help with travel of fox shocks
they would be a pia. If you are looking for a factory fit, look at lucky8 and call or email them. I know the fox shocks they have are great for a 3 inch lift but not sure about a 4 inch. If you are open to other options, call Great Basin rovers. They do the blistein and can set you up with remote resivior or something heavier if you want. I would say coilover shocks would be overkill period unless you have medium duty springs and keep it fully laden but that's just my opinion. I'm sure the others will chirp in with some good advice also
You need to whip out the old tape measure and pencil whip the numbers. All of the compressed and extended lengths for FOX shocks is on their website.
Measure from upper mount to lower mount while your truck is sitting level, that's your shock length at rest. Let's say its 25". An 11" shock has the following specs: Ext.Length:28.10" & Col.Length:17.10"
That means you'll get about 3" of downtravel and 8" of uptravel.
So see where you're at and figure out how much uptravel and downtravel you want and buy the right length shock.
HI Rover
10-11-2015 11:15 PM
HI Rover
10-19-2014 11:51 PM
jpschreff
07-19-2014 08:49 PM
