help with travel of fox shocks
Old Feb 21, 2017 | 05:12 PM
Anson Cone's Avatar
4th Gear
Default help with travel of fox shocks
I have a land rover discovery II with 4 inch terrafirma lift i was wondering what the best fox shock travel would be for my vehicle? Would coilovers be an option in this scenario?
Old Feb 21, 2017 | 06:49 PM
Luckyjayb's Avatar
they would be a pia. If you are looking for a factory fit, look at lucky8 and call or email them. I know the fox shocks they have are great for a 3 inch lift but not sure about a 4 inch. If you are open to other options, call Great Basin rovers. They do the blistein and can set you up with remote resivior or something heavier if you want. I would say coilover shocks would be overkill period unless you have medium duty springs and keep it fully laden but that's just my opinion. I'm sure the others will chirp in with some good advice also
Old Feb 21, 2017 | 06:54 PM
Anson Cone's Avatar
4th Gear
thanks for your help i was also looking at f-o-a shocks and bilsteins. Do you have bilsteins? If so do you like then?
Old Feb 21, 2017 | 08:10 PM
Faulk's Avatar
I have FOX shocks in 3 inch and they are exceptional. They can custom manufacturer anything, just call them up.
Old Feb 22, 2017 | 10:42 AM
Anson Cone's Avatar
4th Gear
What was the travel that you went with on the 3 inch setup. i was planning on ordering from lucky 8
Old Feb 22, 2017 | 11:00 AM
fishEH's Avatar
You need to whip out the old tape measure and pencil whip the numbers. All of the compressed and extended lengths for FOX shocks is on their website.
Measure from upper mount to lower mount while your truck is sitting level, that's your shock length at rest. Let's say its 25". An 11" shock has the following specs: Ext.Length:28.10" & Col.Length:17.10"
That means you'll get about 3" of downtravel and 8" of uptravel.
So see where you're at and figure out how much uptravel and downtravel you want and buy the right length shock.
coors
Nov 25, 2015 10:29 AM
HI Rover
Oct 11, 2015 11:15 PM
NVDiscovery
Oct 9, 2015 08:15 AM
HI Rover
Oct 19, 2014 11:51 PM
jpschreff
Jul 19, 2014 08:49 PM
