help with vin numbers
Old May 10, 2013 | 08:33 PM
zrmcdonald777's Avatar
Default help with vin numbers
I was asked today when checking on plugs and wires if my discovery was vin2 or vin5 what are they asking me??? this may sound stupid but I said 2door or 5door help please
Old May 10, 2013 | 08:39 PM
The 5 door is more common. Plugs are plain old Champion coppers here in the US, and silicone 7 or 8 mm wires. These are thicker insulation than factory, and hold up longer under the hood where Rover keeps it on the warm side.
Not a clue what the parts guy was asking for, here is page on the VIN code info, there is no "five" as a valid value.
File Type: pdf
Old May 10, 2013 | 08:49 PM
thank you I order the kingsborne wires 8mm and idk what plugs to try owners manual says champion and got a lot of bosch +4 from people on here I just don't know what to use thanks again for all the help with my rover questions peace
Old May 10, 2013 | 09:22 PM
caymandrew's Avatar
I know exactly what this guy is asking, or at least what most big brand consumer websites ask, here's a picture from oreillyauto.com vehicle finder:
Almost every auto parts store uses the same online website template for searches, they all ask which vin. I've yet to decipher which vin I have! I'm SALTL but I do have a #2 as the seventh digit in the VIN. Does everyone else have a 2 or 5 as the 7th digit?
Old May 10, 2013 | 09:29 PM
In NAS trucks it will be a "2" for the 4 liter V8, 9.35:1 compression ratio (high compression by Rover standards), there is also a low compression 8.2:1 variant of the engine, perhaps a California emissions model? But the shop manual does not show a "5" as a valid value.
Old May 11, 2013 | 11:13 AM
SuperSport's Avatar
What year is your Disco? On my 2003, they want 4 or 6. Mine is a 6 as per the 7th digit. SALTL16483A8xxxxx
Old May 11, 2013 | 11:49 AM
roverguy7's Avatar
My VIN breakout chart is showing 7th digit as follows:
1 = 4.4 M62 & 3.5 V8 (87-88)
2 = 2.5 KV6 & 3.9/4.0 V8
3 = 4.2 AJV8 (SC) & 4.2 V8 (LWB Classic)
4 = 4.0 V6 & 4.6 V8
5 = 4.0 V8 LEVS & 4.4 AJV8
6 & 9 = 4.6 V8 LEVS
LR2 uses 8th digit as engine code, which would be "A" for the 3.2 SI6.
Old May 12, 2013 | 11:18 AM
mine is 2001 disco II SE7 with 93,021 miles vin# SALTW12441A721203
Old May 12, 2013 | 11:41 AM
Sounds like 4 liter gasoline
Old May 12, 2013 | 12:11 PM
jafir's Avatar
2 is normal, 5 is SAI (referenced as LEV in that chart)
