Help w/Electrical - all windows, gear shift box
PNW_disco2 (09-05-2023)
@PNW_disco2 Thanks, my issue is a bit different then your's but I'm very suspect of my cabin fuse box since my sunroof have been leaking since before I purchased it. My thread if you are interested. Did you clean up yours and that didn't help I assume?
Yup, sounds like a similar issue. Awesome, I'll follow your thread. I haven't cleaned it off yet or tried to reinstall it. I'm considering purchasing a new box because it was such a PITA to take out that I shudder to think about having to put back in then take it out again..... And I'm also deep in the midst of the dreaded head gasket repair, so the electrical voodoo is on the back burner... I remain suspicious of the center console LOL
That fusebox. Even though it doesn't look bad, it has a few spots of medium / noticeable corrosion. I'd bet on that.
I think you'll drive yourself mad with wiring diagrams because nothing will actually make sense (went thru this on one for awhile years back).... if you don't first replace the fusebox.
Stephan Wegmüller
04-29-2019 05:04 PM
