helpp
Old Sep 14, 2007 | 07:49 PM
atvrdr's Avatar
Default helpp
hey guys new to this forum and have a 97 disco althought today when iwas about to the house i turned on the car and the tried to move the shifter to drive but its stuck at park it wont pull back to anything ive had this car for 3 years and had nothing wrong with it until now.....thanks for all the help in advance
Old Sep 14, 2007 | 07:51 PM
okdiscoguy's Avatar
Default RE: helpp
Check your brake light switch. YOu have 2 on your pedal lever. One os for cruise and one is for brake lights and the neutral lockout. Lots of four wheelers keep a spare switch for just this reason. Turn your truck on and see if you have brake lights.
Old Sep 14, 2007 | 07:54 PM
atvrdr's Avatar
Default RE: helpp
thanks for the quick reply if the brake lights are on what do i do?? and if there off what do i do???
thanks alot
Old Sep 14, 2007 | 07:59 PM
okdiscoguy's Avatar
Default RE: helpp
If they are off, replace the switch. If they are on, move on to the neatral saftey switch. When the brake light circuit is energised, it energises a solenoid in the shifter. You should hear a little click from the center column along with 2 faint clicks near the brake pedal.
Old Sep 16, 2007 | 07:17 PM
atvrdr's Avatar
Default RE: helpp
i have a 97 and the shifter that has the lock and neutral is on lock and to turn it off the car has to be in neutral what would i do since the car cant go in neutral and also the anti lock light is coming up
Old Sep 16, 2007 | 09:34 PM
okdiscoguy's Avatar
Default RE: helpp
ok, I didn't mean neutral safety switch. There is a lock out switch that will not allow you to shift from park unless you hit the brake. If your brakelight switch fails, you can not shift from park.
Antilock will light everytime you turn it on. That is normal. It should turn off after you have pulled off alittle ways. If it stays on while driving, you ahve to get the codes read by someone with a proper scanner, not just Autozone.
Didn't really follow your post, but I have a 97 as well. Do you have brake lights with the ignition on and hitting the brakes?
