Here she is 1999 Discovery
Well here is the new (rough) Discovery I picked up.
Didn't run previous owner said it needed a fuel pump, replaced a blown fuse and now it runs. Truck is pretty beat up, obviously maintenance wasn't a priority. Only drives in reverse, I can change the gears all the way through but no go in the forward gears. Got under to look at the tranny oil level and the level plug wasn't there (was in a cup holder). Hi/lo lever is stuck.
So far I have changed the oil and filter, replaced fuses, and drove it in reverse.
Should be fun!!!
A quick wash to see what was under the dirt...well more dirt
Should be fun!!!
Should be fun!!!
Should be fun!!!
Took busted back bumper cover off, front right blinker, shattered windshield fluid reservoir, and cleaned up some plastic. I am trying to decide if I want to sink money into repairing the transmission or just replace it. Mostly because I have no idea what problems it has had in the past. What do you guys think? Replace or repair.
You said you found the transmission check plug in the cup holder. Did you check the trans level. This isn't just a oh it's good check. You need to cycle through each gear and for each gear add fluid. If you have not done this you have no info to tell if the truck has fluid in the trans. this is the place to start. if you have done this and have a full level then we can talk more advanced diagnosis.
