Hey !..while your'e down there....
Old Aug 16, 2009 | 09:45 PM
XCELLER8's Avatar
Default Hey !..while your'e down there....
so as I'm finishing the install of my new cat back exhaust , (purch. from AB on sale $ 269) and swearing at the fit...I notice gear lube starting to drip from the input shaft on the rear diff. thats GOOD news 'cuz that means there's still oil in it !! so I've prepared myself for replacing the seal and befor I actually order one I thought I should check the vent line....it was clear but the banjo bolt and vent nipple were corroded solid !! took it out and ran a drill through both to clear them out....pretty easy fix......I actually heard the air vent out as i removed the bolt...that should cure the leak
but here's a reminder to check these now and then !!
Old Aug 16, 2009 | 10:23 PM
98roverguy's Avatar
That's a great tip. Thanks for bringing that up.
Heddy
Jan 15, 2015 04:30 PM
Sabotage
May 28, 2013 05:17 PM
Hox
Jun 9, 2011 05:42 PM
bgfnbr
Feb 10, 2011 01:50 AM
Second2None
Apr 24, 2010 04:46 PM
