HID Conversion?
Old Jan 13, 2013 | 06:20 PM
Shade Tree's Avatar
Originally Posted by Shade Tree
My HID's work way better than the stock halogens. Unless you get the Hi/Low kit you won't have any high beams. Reflector HID's are normally reserved for stock lights, but there are some Reflector kits available for big $$$$$$.
I said "Reflector" but I meant "Projector" kits.
Stayed up to late that night I guess. Sorry for the confusion.
Old Jan 14, 2013 | 08:46 AM
jbarr89's Avatar
Default HID projector retrofit
this is my write-up from last year of my retrofit, scroll down the page a bit to see the pictures.
overall I am happy with the results, i use these along with driving lights in the bumper for plenty of light and no, I do not have glare or blind oncoming traffic. the projectors are aimed the same as the halogen housings and the cutoff does not allow any light above that. I have about $200 in them with everything
HID Projector How-To on a 03-04 Discovery-lots of pictures - Land Rover Forums : Land Rover and Range Rover Forum
Old Jan 14, 2013 | 10:48 AM
KindaGuitarded's Avatar
excellent write up, i think i might see if i can source a pair of donor lights to try this on.
Old Jan 14, 2013 | 10:40 PM
discoboy's Avatar
I see you have a 2003 D2. I have had my HID retrofits installed installed in my 03 D2 for over 3 years now. The way our headlamps are setup do not blind drivers, provide a good spread and does not scatter. On a pre 2003 D2 I can definitely see those headlamps providing scattered lights when retrofits HID are installed. I use a 4300k bulb, in my opinion 4300-6000k is close to stock on most cars, the ricers are using 10+k and that is plain stupid not to mention useless in the rain. I say go for it, you won't regret it.
Old Jan 16, 2013 | 04:37 AM
winaje's Avatar
Originally Posted by Street Wolf
Aim them correctly and you'll be just fine. This 'blinding oncoming traffic' nonsense is fantasy land.
I'd respectfully disagree. HID's are designed to have a projector to focus and shield the light. The D2 light assembly is designed to focus a halogen lamp specifically, as the halogen lamp has the low beam filament shielded in the globe.
And believe me, even Down Under, Joe Schmoe knows that the D2's didn't come with HID's, took some fast talking to avoid a hefty fine at a breath testing station because of the HID's I had fitted at that time.
Old Jan 16, 2013 | 06:08 PM
antichrist's Avatar
Originally Posted by KindaGuitarded
my understanding is with a Glare Shield(or casper shield depending on your geographical vernacular) you can correctly use a HID kid in a reflector style housing without to much glare and a proper beam cutoff.
Nope, you can't. Not possible in a halogen housing.
It's a common misconception that beam cutoff is what it's all about.
Old Jan 16, 2013 | 07:51 PM
Hey Kinda, I want to see your Jeep.
Old Jan 16, 2013 | 07:53 PM
I posted a picture of it in the "Coolest Car " thead in "off topic" section
scarlettwu
Off Topic
Mar 25, 2009 02:10 AM
bangkuaidiscovery04
Mar 16, 2009 08:48 AM
snowplower
Nov 11, 2008 05:35 PM
fanatic516
Aug 19, 2007 10:27 PM
DV57
May 26, 2007 07:52 AM
